Header collars
  • liliysdad
  • liliysdad's Avatar Topic Author
Header collars
06 Jul 2007 19:58
#155208
I am installing a Supertrapp 4-1 header on my 94 KZ100P. When I put the collars on the exhaust, and tightened the flanges up, it appears as though the collars are too short, failing to seal the gaskets. Is this something common? What collars do I need to remedy this?
  • FloridaBiker
  • FloridaBiker's Avatar
Re: Header collars
07 Jul 2007 06:01
#155285
By collars do you mean the 2 semi circle pieces per pipe?
If so, the most likely cause is the collars are in backwards.
Z1 Enterprises offers a Yamaha exhaust gasket which works much better than the Kaw part, which they also sell.
  • barney
  • barney's Avatar
Re: Header collars
07 Jul 2007 07:00
#155289
If the collers are too short you may need taller ones. I had to bug the local Kawi dealers parts guy to bring in a couple of different sets till I found the right ones. If you find this is the case,let me know and I'll find out what I ended up using.
  • liliysdad
Re: Header collars
07 Jul 2007 07:27
#155291
Yes, I am referring to the two semi-circle clips. They may be in backwards, but I dont think so. I am placing the larger, flared end toward the flange, narrow end toward the gasket. I am already using the Yamaha gaskets from Z1.
If you dont mid, I would like the part number and application for the longer collars.
  • barney
  • barney's Avatar
Re: Header collars
07 Jul 2007 07:47
#155293
Not sure about the application(77 KZ1000 I think).They are part #92027-1457 X 8 peices. You can cross reference these on Kawasaki.com,click owner info, then click Parts diagrams.
