Torque
- Lorcan
- Speed Loony
Re: Torque
06 Jul 2007 14:41
140 ft/lbs
Post edited by: Lorcan, at: 2007/07/06 17:43
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- PLUMMEN
Re: Torque
06 Jul 2007 17:25
if you still have the 900 crank in your motor its a big plus,but that extra bit of rake is also helping hold you down.wheelies are a waste of power when you are racing the trick is to put the power to the ground and accelerate,very hard to do when your busy looking at the birds!
wireman was quite the wheelie riding nut when he was young but after many smashed kerkers,blown fork seals and cracked steering head gussets he too learned the hard way !
- Z1R rider
Re: Torque
06 Jul 2007 19:50
Lorcan wrote:
that's got to be like getting shot out of a cannon!!:woohoo:
140 ft/lbs
<br><br>Post edited by: Lorcan, at: 2007/07/06 17:43
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
- themachine
Re: Torque
06 Jul 2007 22:12
my 1170 on stock cams with a ported head will bake the rear tire into second Without dumping the clutch, but no wheelie.
i'm only 150lbs and it has an extended swingarm too so that doesnt help.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- tjettim
Re: Torque
07 Jul 2007 06:19
Put the bike on a dyno.That is the only way you
will know where and how much torque you have.
- mark1122
- Keep twisting it
Re: Torque
09 Jul 2007 19:49
I reringed and i am getting 150psi compression warm and dry and 175psi with a little oil added.i only have 150 miles on it so maybee the rings are still seating.i' ll have to look up the #'s for my cams but they are .425lift and about 265 duration.I had the lobe centers at 110 and now have them at 107in/111ext.sounds like i need less duration to pic up the compression?Like some ape k410 cams? how much psi can i run on pump gas?Waiting for my turn on the dyno,4 weeks.
Post edited by: mark1122, at: 2007/07/09 23:50
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Snakebyte
Re: Torque
10 Jul 2007 04:27
The intake closing event is determined by the duration and intake lobe centerline of the camshaft, as well as the actual position of the cam as installed with respect to the crank. When the intake closes you start to build compresion. I dont know the specs on the cams you are looking at but I can tell you that if you advance the cam OR get a tighter lobe separation cam you will get more compression.
- Snakebyte
Re: Torque
10 Jul 2007 04:36
At what degree does your intake valve close???????? From when the cams were straight up and now whith the tighter lobe separation.
When does the intake valve close on the new cam??? And what is the lobe separation???
- violentvintagecycles
Re: Torque
10 Jul 2007 21:11
Hey, about those wheelies.. I luv doin em too, had a honda nighthawk 450 that was a little wheelie machine.. Unfortunetly, never even THOUGHT of checking the frame for cracking.. Coming down off a wheelie one day lost the forks, the triple tree, everything.. Cracked the frame and split it..So, if your gonna be doing wheelies all over the place, REINFORCE the frame! By the way i landed in a big ass mud puddle and slid the rest of the way. Stopped in front of my friends door.. Not a scratch.. :silly:
- Sandy
- Fly High,Tony
Re: Torque
10 Jul 2007 21:50
All I can say is that any wheelie that I've done on My Bike...it does NOT land softly!Unless I can plane out nice and gradual,but for the most part,it lands like a bloody tank.:pinch:
I don't do them very often...mostly when I'm encouraged.:whistle: :laugh:
1977 KZ1000 A-1
- Snakebyte
Re: Torque
11 Jul 2007 05:37
Back when I had 16-41 sproket I could do wheelies by rolling at 4g then snap close the throttle and then opening up the throttle and yank back. Wheelied good and I would hold the throttle open all the way and keep it open till the front end came down. The landing wasnt bad at all almost soft, just keep your weight back and the throttle open when you want to come down tap the back brake.:sick: Its not easy to learn to do a proper wheelie cause your reaction is to snap close the throttle:pinch: then slam the front on the groung, but if you hold the throttle and hit the back brake you will land smoother then closing the throttle.
The following user(s) said Thank You: stevefarris6
