Something strange on oil plug
- rgpbeme
03 Jul 2007 20:44
Hi maybe someone can give me a little help. I changed the oil in my 79 mk2. When I pulled the plug on the pan there was a piece stuck to it. The piece is about 1/4" wide and 1/2" long. It was dark red and looks like it has wear marks on it from something sliding on it. It looks like it could be hard plastic but it was stuck to the magnet in the plug. I don't want to ride the bike till I find out what it is.
Ron in arkansas
Ron in arkansas
- Sandy
- Fly High,Tony
- donthekawguy
Re: Something strange on oil plug
03 Jul 2007 21:18
Sounds like the cam chain guide. Not sure why it's red. Thats usually the only thing that falls apart on kawasaki motors. It's a bummer because you will need to pull the head and cylinders to fix it. Before you do that you should pull the oil pan and see what else falls out to make sure it is the guide.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- themachine
04 Jul 2007 08:13
if its orange on one side it could be the magnet from the stator, i had mine rub on something and slowly chip away.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- rgpbeme
04 Jul 2007 14:45
Thanks I never thought to see if the piece was the charged one and it was sticking the oil plug. I will check that later.
