emissions blockoff?
- themachine
emissions blockoff?
29 Jun 2007 11:35
can i block off the exhaust emission lines that come from the top of the valve cover without it affecting the performance/driveability of the engine? otherwise what are your ideas to clean it up?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
Re: emissions blockoff?
29 Jun 2007 11:51
on my 1980 z1r it has a hose connecting them,to each other.not sure about that but it has been like that since i got it.never noticed any effect.ape racing has some billet plates that replace both covers.might ck that out.
- coppertales
29 Jun 2007 12:59
Because all the rubber hoses connecting the emission parts together were cracked, I just made a blocking plate out of aluminum and replaced the valves with them then ran a piece of hose between the two outlets. The other bike just has the hose. Both run just fine.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- Bluemeanie
30 Jun 2007 05:12
I run a hose on mine, you could also drill and tap the ports on the head for allen plugs and then you could install a "standard" cover.
- darmahsd
30 Jun 2007 21:04
Try finding that "standard" cover. The Canadian bikes had the pretty covers with no "clean air" exhaust reed valve covers. Last one I tried to get was from an 1100 Spectre from eBay Canada. I was sniped all the way to Pluto!
'Gonna thread some aluminum rod, plug the holes and just mill down the reed valve box flush with the floor of the chamber and do away with any fancy (expensive) billet covers. I saw these available already done on eBay not long ago and they weren't expensive. A little black krinkle paint and you're close to the clean look of the Canadian engine with no real effect on emissions.
That was another government (political) thing if they wanted to sell more bikes here (IMHO). The reeds would open up from the negative intake pulse to let fresh air into the exhaust to help burn any leftover charge.
Don't ever put those reeds in flopped, pretty nasty.
Don't ask how I know
Stephen
Post edited by: darmahsd, at: 2007/07/01 00:08
Stephen
- darmahsd
30 Jun 2007 21:08
Stephen
'84 GPZ 1100
Stephen
'84 GPZ 1100
- darmahsd
30 Jun 2007 21:08
Stephen
'84 GPZ 1100
Stephen
'84 GPZ 1100
- darmahsd
01 Jul 2007 09:10
'Sorry for the three copies of same post. Don't know what happened.
Stephen
Stephen
