'nother oil light problem...
- Beepy
28 Jun 2007 08:08
Ok... this problem is a bit diffrent than the question recently.
I just finished an upper end rebuild on a 1999 kz1000p that I picked up that for some reason had a warped head (there was only 21,000 miles on it).
When I fire her up in the morning everything is fine, but when she warms up the oil light comes on when the engine is below 2,500 RPM's. As soon as it goes above that the light goes off. Has new 10W30 oil and does not leak.
Any ideas for the most likely cause?
- PLUMMEN
Re: 'nother oil light problem...
28 Jun 2007 10:10
check your oil pump and screen,when you rev up the motor your oil pump spins faster;)
- BSKZ650
28 Jun 2007 11:21
thought you were supposed to use 10-40 oil
77 ltd1000, current rider
76 kz900, just waiting
- Beepy
28 Jun 2007 19:48
The manual gives the diffrent ranges at which each oil can operate. I just changed the oil to 20W50 and now the oil light only goes on at when it is at idle, (~1,000 RPM)...
Since when I am riding the engine is not at idle much of the time, I hope that I don't have to tear anything apart right now....
- MDawnz1
28 Jun 2007 21:39
It could be a lots of different things ......
The first to check would be the switch ,
swap in a different or new one and see what happens .
Small ,easy and cheap ,
to start with ,
I just watched a PRO engine builder (cars)
sling in 4 sets of NEW bearing ,2 NEW oil pumps and about 30 qts of oil and new filters plus all the NEW gaskets all that took ,in one night .
BB Chevy engine.
By the way ,I DON'T LIKE THIS GUY and was there with a friend .
I kept my mouth shut the whole time sipping my beer until I just could NOT take it any longer.
Pis*ed him off asking if he had checked the gauge in the race car .
End of a long and funny story ,
It was a $35 gauge ........
The moral? Start with the basics.
to start with ,
BB Chevy engine.
1974 Z1a, still 903
- BSKZ650
29 Jun 2007 05:08
must not be much of a engine builder, he should have used a set of mics to make sure it was right prior to building the engine
- Beepy
29 Jun 2007 19:17
so when I pull the switch off, how do I check that it works?
My Clymer manual makes no mention of it. I did see that there is a port right above the ignition coil and that I could screw in an oil gauge. NOONE in town has a gauge that I can screw in there. If worst comes to worst where can I get one?
- PLUMMEN
30 Jun 2007 07:15
MDawnz1 wrote:
yeah that would of been entertaining to watch!It could be a lots of different things ......
to start with ,
BB Chevy engine.
