Changing a cam chain...
  • eel
  • eel's Avatar Topic Author
26 Jun 2007 06:41
#152782
have to split the cases?
1984 GPz750
2007 ZX6R
53-Racing.com - My Website
My GPz
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: Changing a cam chain...
26 Jun 2007 06:44
#152783
I didn't on my '85 GPz.
Z1 sells the chain, link and tool. Give them a call.
'85 GPz550(ZX550-A2)
  • wiredgeorge
  • wiredgeorge's Avatar
26 Jun 2007 07:39
#152793
Eel, place your bike year/model and your location in your signature. Who knows what type bike you refer to? As far as splitting the cases on a KZ, they do have to be split to install an OEM cam chain. You can use an aftermarket chain with masterlink but will not be able to change out any of the associated rubber bits that do wear if you go this route unless you take the top end off anyway... Might as well split the cases, in my opinion unless you know the rubber bits are good.
  • eel
26 Jun 2007 08:22
#152808
sorry folks.. its for an 84 GPZ750
i already have the top end, barrels off.. i went to order the chain and the parts guy asked if i needed a bunch of other seals from inside the cases.. i said.. no, why.. he said i was going to split the cases to change the chain, right?
i was sure there was clip-type chains available..
because i dont want to open up the motor unless i really have to..
1984 GPz750
2007 ZX6R
My GPz
  • wiredgeorge
26 Jun 2007 08:41
#152816
The engine seals don't go inside the cases... they go in the case covers and it isn't a bad idea to swap them when rebuilding an engine. For a KZ 900/1000 the seal kit is under $30 as memory serves... shift shaft seal, seal on the crank end where the pickup coils are located, seal around the kick starter lever, etc... To split the cases, you only have to remove about 7 bolts from the top and about 23 (or 21? can't recall for sure) bolts from underneath and there are 8mm pry points where you insert and 8mm bolt and just turn it a bit and the cases are split. You just lift the crank and slide the new chain in place. The biggest issue with splitting the cases is installing new engine cover gaskets so a full gasket set is needed. At this point you can check out the transmission, replace the oring under the oil pump and clean the oil pump up... It takes about $100 to split the cases if you change seals and gaskets and a couple extra hours work.
Oh yeah, the guy at the parts counter has NO idea that there is a master link type chain you could use as they never put a master link type cam chain on a Kaw... I think you have a hyvo chain and they do make master links for those...
Post edited by: wiredgeorge, at: 2007/06/26 11:42
  • eel
26 Jun 2007 10:28
#152852
how safe is the clip/rivet link in a racing application.. and recommended brands.. i think its just the parts guys might not know where to look for one..
1984 GPz750
2007 ZX6R
My GPz
  • katjbus
  • katjbus's Avatar
26 Jun 2007 11:08
#152864
oem chain your best bet rivet style should be fine but clip style not safe
  • wiredgeorge
26 Jun 2007 12:56
#152890
I have never used a master link type hyvo cam chain. The master link chains (bicycle type chain) on a 903/1015 has you set the plate OVER the side pins and then you must PEEN the pins (or stake them if you prefer). I am pretty confident that if you peen/stake the pin ends correctly, the link is at least as strong as any other. I suggest you call z1enterprises.com and ask Jeff or one of the guys how the hyvo master link works and how strong it would be relative to racing applications. Deal is, that the real high quality bicycle type cam chains don't come in the master link variety, as far as I know... only the less expensive. Could be there are different grades of hyvo chain and they will have some good recommendations as far as how they stand up to racing stress.
  • wiredgeorge
26 Jun 2007 12:57
#152891
I have never used a master link type hyvo cam chain. The master link chains (bicycle type chain) on a 903/1015 has you set the plate OVER the side pins and then you must PEEN the pins (or stake them if you prefer). I am pretty confident that if you peen/stake the pin ends correctly, the link is at least as strong as any other. I suggest you call z1enterprises.com and ask Jeff or one of the guys how the hyvo master link works and how strong it would be relative to racing applications. Deal is, that the real high quality bicycle type cam chains don't come in the master link variety, as far as I know... only the less expensive. Could be there are different grades of hyvo chain and they will have some good recommendations as far as how they stand up to racing stress. Oh yeah, I haven't see a "clip" type master link on a chain ever... By clip, I am guessing the type of fastener used on a drive chain made to be removeable.
  • APE Jay
  • APE Jay's Avatar
26 Jun 2007 15:29
#152919
Something to consider. On the 903/1015 motors there are heavy duty cam chains available for under $50.00
There are no heavy duty put together chains.
And remember, when those chains fail, we can fix your head :P
Jay
  • steell
  • steell's Avatar
26 Jun 2007 16:22
#152935
On the 750 fours the crank seals are inside the cases and the crank has to be removed to replace them.
  • Snakebyte
  • Snakebyte's Avatar
28 Jun 2007 04:47
#153345
If they sell a master link then just cut your chain and link the new chain to the old and pull it through the engine no need to split the cases, just take the valve coverr off.
