shaft to chain conversion
  • jasbarsydvic
  • jasbarsydvic's Avatar Topic Author
25 Jun 2007 14:47
#152627
Anyone done this? I have a 1100 that i did this to and everything went great but one thing. It doesn't shift right. It does shift but not right. If anyone can help it would be great. It has to be something behind the trans door that i didn't or did do.
  • FloridaBiker
  • FloridaBiker's Avatar
Re: shaft to chain conversion
25 Jun 2007 15:34
#152640
Can you be more specific about the shifting problem?
  • jasbarsydvic
25 Jun 2007 16:04
#152649
Its not smooth and you have to shift it twice before it goes into a gear. Its hard to get it into 1st and back into neutral.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
25 Jun 2007 19:08
#152682
Have you looked at the shift fork and drum?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • wiredgeorge
  • wiredgeorge's Avatar
26 Jun 2007 08:44
#152817
Changing to a chain won't affect how the bike shifts. Do some research on external shift mechanisms... I have gone through this a number of times... usually associated with "popping out of gear" or some similar topic.
  • jasbarsydvic
26 Jun 2007 17:00
#152947
Ok i changed the output shaft, the clutch pusher, and i moved the red to the blue and now im have trouble shifting. I was told this today by Oldmankaw.
"You need to use the chain drive shifter pawl,your calling it the shifter rod, the splined shaft the shifter pedal attaches to that moves the shifter drum. The lengths from the shaft to the shifter and overshift limiters on the upshift and downshift forks is different. Also use the chain drive clutch pusher rod (I assume you already got it with the output shaft swap)"
Anyone else hear of this?
Post edited by: jasbarsydvic, at: 2007/06/26 21:33
Post edited by: jasbarsydvic, at: 2007/06/26 21:34
  • jasbarsydvic
26 Jun 2007 17:01
#152948
I have a picture but i can't get it small enough for the forum!!!
