What comes apart when RPMs go too high?
- WABBMW
- Let The Good Times Roll !
25 Jun 2007 11:53
I have only had my '82 KZ650 CSR H2 for a couple of months, and plan on leaving it completely stock. The engine runs great and revs very easily, so I am very careful to keep the RPMs from going anywhere near the red line on the tach, which is at 9,500. I have read that these engines are very durable, but being a curious, engineering type guy, I wonder just what finally does let go in these engines when they are over revved.
Sorry to be so morbid, but I wonder what the weak link is, that finally does come apart and at approximately what RPM. Surely some of you high performance owners can answer this. Thanks.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- GPzephyr
Re: What comes apart when RPMs go too high?
25 Jun 2007 12:50
The first thing that'll happen is the valve springs will lose control of the valves. Usually referred to as valve float.
You will probably be safe 'til about 10.5-11k though.
1991, Zephyr 750. GPz750 turbo engine, 810cc, Garrett T25 turbo, GPz1100 throttle bodies, 310cc injectors, Power commander, Dyna coils, Lots more as well...
KB Saturn fitted with a stock GPz750 turbo engine. Loads to do on this project.
- Z1R rider
25 Jun 2007 15:06
Little brother's 82 GPZ-550 lasted one summer with repeated runs to and beyond redline, the rod bearings finally let go and messed up the crank. No undersized bearings for it (hardened journals?) so he sold it for parts.
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
