- Thank you received: 4
bypass vacuume?
- themachine
23 Jun 2007 09:49 #152063
by themachine
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
bypass vacuume? was created by themachine
can i just plug off the vacuum nozzles on my carbs?
- vach
23 Jun 2007 09:58 #152064
by vach
1979 kz650 B. Chicago, Illinois
Replied by vach on topic bypass vacuume?
I asked the same question.. I was told you can.. Do you have a vacuum petcock?
- themachine
23 Jun 2007 11:39 #152085
by themachine
Replied by themachine on topic bypass vacuume?
no vacuum petcock, just a good ole valve!
- wiredgeorge
23 Jun 2007 12:07 #152093
by wiredgeorge
Replied by wiredgeorge on topic bypass vacuume?
Since Vach has VM series carbs, I would think about what needs to be done with BS series carbs on the J bike with an emissions system. Definitely cap the vacuum ports using 7/32" caps. Then trace back any hoses that go to a tee and a vacuum line and then to a vacuum switch. Remove this stuff. There are some bigger hoses associated with the vacuum switch... those over your reed valve ports. Remove the hoses and plug the holes on the spigots they came off of on your valve cover.
