chirping under accelleration
- brianrae33
22 Jun 2007 17:18
hey all...fyi..running close to 11-1 cr, run nothing but 93 octane..now the question..when hot..and usually at highway speeds, say around 75 to 80 in 5th...if i crack it without downshifting..it goes like hell but get an occaional chirping sound coming from the top end..now i know these old kaws don't like stop and go but this is at highway speeds..not grinding or knocking at all..but chirping..any ideas??
thanx in advance for any input..
1982 kz1000ltd
- The Milkman
Re: chirping under accelleration
22 Jun 2007 17:28
I'm not sure if the 1000's have it setup the same, but my 650 was making a noise similar to what you describe. It turned out to be the top cam chain roller. Luckily I have a spare engine I could steal one from.
Ride safe
Ride safe
- katjbus
- themachine
22 Jun 2007 19:34
perhaps a dry secondary squeaking open?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- brianrae33
22 Jun 2007 19:47
replaced all my idler gears with liska billet ones..situation occurred before as well..gotta be either octane or shitty original cam chain tensioner..at least my best guess
1982 kz1000ltd
- mark1122
- Keep twisting it
22 Jun 2007 20:48
Dont understand ,chirping?like a robin or a blue jay?lol.(sorry i couldnt resist)U must have had it apart recently and put in the liskas,Right?what did the front cam chain guide look like.I hear they are known to go?Not much to go wrong with the tensioner though?Poor octain would give u a ping at lite acceleration.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Z1R rider
23 Jun 2007 05:20
:blink: chirping? :dry: I guess what I would try first is run a tank of 110 race gas and see if it goes away. My 1105cc with 10.25 compression (if you trust Wiesco,I've never done the measurments & math) would always rattled with 93 oct. In 100+ heat it could hardly pull it's self down the road at 60 mph without rattling. This spring I finally got busy and put an extra base gasket under the jugs. Now it has only a very light rattle when warmed up at full throttle on 89 octane and have yet to notice any power diffrence.
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
- kzwolfsr
23 Jun 2007 13:10
I would pretty much say that that is a noise of air escapingunder pressure. Retorgue head bolts and check for an exhaust leak. Also check your sparkplugs and see if they are torqued down.
Original man of the Caribbean
- reborn650
23 Jun 2007 15:19
brianrae33 wrote:
Pick up a manual chain adjuster from APE. There are beautiful works of machined art and you can have faith that it is not going to let the chain go slack and jump a cam tooth. I won't run another type on my bike ever again.
Jeff at Z1 enterprises has them.
Cheers - Colin Firth-Ontario Canada
-1998 Jeep TJ Wrangler 4.0...
