6-pack in pieces..
- gulag
6-pack in pieces..
29 Dec 2005 13:33
Hi gang,, just thought you might find it intresting to see how the process is coming along with my z1300..
Engine is out, and in pieces, a bit of old dirty oil in there but looks surprisingly good, bearings, pistons etc..
I am going to port and polish the head, and it is tempting to do the same with the pistons and the rods,, ill see about that one..
I want to be able to adjust the timing on the cams, so i might machine the cams down and install adjustable sprockets, (original is machined in 1 piece, cam+sprocket)
well,, pics on my website for those intrested..
have a good one !!
www.johannsson.net/Myndakerfi.aspx?id=7
have a good one !!
- Mcdroid
- Gone Kwackers
Re: 6-pack in pieces..
29 Dec 2005 13:48
Only a fool or a brave man takes apart a Z1300...I have been a fool a number of times, so that must make you the brave man:laugh: Thanks for the pictures!!!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- GargantuChet
29 Dec 2005 14:38
Good to see you're still around! Keep the pics coming...
- KevZ
29 Dec 2005 14:45
Good luck Gulag. Looks like you have your work cut out for you. How long do you plan on this project taking?
- ejshotgun
29 Dec 2005 17:35
Damn that looks like work/fun.
That going to be one fine machine when you get it done.
Thanks for sharing.
Thanks for sharing.
- KZQ
- Administrator
29 Dec 2005 18:17
Hey Man,
I looked at those coils and said NO WAY! Then I looked at your gas tank, Yeah that'll work.
Check out ZI Enterprises for any small parts you might need, valve seals etc.
I just picked up a spare head on E-Bay. When I tore it down I found it to be in really good shape. I'm just going to polish it up and put it back together. I'll use it as a spare heading for a whole spare engine.
I'm a bit of a 1300 nut, I've got two of them.
Thanks for the pics.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- kwakagoose
29 Dec 2005 18:21
Very cool.
What are you go to do with the body? Is that your style the way it looks now?
Post edited by: kwakagoose, at: 2005/12/29 21:22
- gulag
30 Dec 2005 06:20
Hi gang,, thanks for the pep-talk
I am actually a motorcycle mechanic, graduate of MMI, motorcycle mechanics institute since 1992, I have worked on various high performance bikes and cars over the years so Im not a total noob to the game
Im not working as a mech but I still love the game..
About the body/frame, Im not quite sure where to go with that one, I am even considering painting the engine kawasaki green !!!
and the tank and fenders as well,, but its only an idea. I am definatly going to put a wide rear rim under, 10" preferably, and stretch the front forks a bit, not too much though..
the engine work will hopefully be finished in a couple of months, fram work, hmm, I dont know, the swing arm / rim work will take some time.. well see
I am taking the engine block to be glass blasted next week,
and the tank and fenders as well,, but its only an idea. I am definatly going to put a wide rear rim under, 10" preferably, and stretch the front forks a bit, not too much though..the engine work will hopefully be finished in a couple of months, fram work, hmm, I dont know, the swing arm / rim work will take some time.. well see
