Andrews cam question
  • kawtoy
  • kawtoy's Avatar Topic Author
17 Jun 2007 14:13
#150245
I have a set of cams but not sure they will work with my set up. They are Andrews, intake is 8X (.410 lift, 266 deg duration) exhaust is 4X (.430 lift, 286 duration). I not familiar with what cams will work with what setup. I have 80 KZ1000, 10.25:1 compression, 34mm carbs, accel coils, dyna ignition, light port and polish, Vance & Hines sidewinder with open megaphone. Will these cams be worth a crap with this setup? Will I need to go to under bucket shims? Will I need to clearance the head and valve cover? Thanks in advance.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • donthekawguy
  • donthekawguy's Avatar
Re: Andrews cam question
17 Jun 2007 16:42
#150261
Pingel says anything over .420 needs shim under buckets. I would probably go with the s.u.b. just in case.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • kawsakiman
  • kawsakiman's Avatar
17 Jun 2007 16:47
#150262
i have my head out right now to get cleared for the cams.
i did the cover myself.
shim unders are being used so it don't spit a shim at higher rpm's
nice staggering of profiles but i think they will come to life in the upper range
