Kickstart...
  • hobodan
  • hobodan's Avatar Topic Author
Kickstart...
14 Jun 2007 13:34
#149384
So, I need to tear into my motor to repair the starter clutch... But i know how to do that thanks to the search function! :side:
My question is, since I am in there, can I remove the kick start mechanism as well? or will I have to break apart the case as the book leads me to believe... :(
Thanks in advance
-Dan
1977 KZ650-B1 frame and engine. Random pile of parts for the rest.
  • mariozappa
  • mariozappa's Avatar
Re: Kickstart...
14 Jun 2007 13:50
#149395
Keep it!
It will probably save your ass more than once.
Mine did.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • hobodan
Re: Kickstart...
14 Jun 2007 15:16
#149434
oh no, i don't want to get rid of it, thats currently the only way to start it, but it slips really bad sometimes, so i was curious if i could replace parts!
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Kickstart...
15 Jun 2007 05:00
#149593
I believe cases have to be split. You can split the cases by pulling the engine and just pulling off the bottom case after removing the case covers. Quite a bit of gasket scraping but you don't have to pull the block or head.
