Oil in Extreme Heat
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: Oil in Extreme Heat
15 Jun 2007 21:51
Gosling1 wrote:
I couldn't agree more one of Canada's best exports.
:laugh: :woohoo: :whistle:
I don;t know how it will do in that kind of heat, but I found that when I switched to royal purple the damn thing just ran better. It took less time to warm up, shifts smoother and just idles better. I know smome people don't like royal purple, but I think it's just the best stuff out there. The only down side is it can be a bit pricey.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Gman
16 Jun 2007 04:15
I use the Honda 20/50 non-synthetic 4-stroke motorcycle oil. It's good stuff. I realise it costs a bit more than car oil but I like the research they put into their products.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
- ejshotgun
16 Jun 2007 07:43
I've used Castrol 20-50 (I don't know if it was GTX back then but that's what I use now) in the summer since I started riding back in the mid seventies.
This has included Nevada/California/New Mexico/Texas/Oklahoma. I use 10-40 in the winter.
No problems.
No problems.
- Grebnaws Inc.
16 Jun 2007 11:32
austin3119 wrote:
Rotella dropped their zinc? I had no idea, or I wouldn't have put it in my bike. I need to go track down these numbers and see where the changes were made. If that's the case I'll be switching over to Chevron Delo with my next change.
I just changed to the Chevron Delo 15w-40 diesel oil. As of the beginning of 2007 a lot of the oil makers dropped their zinc and phosporous levels which I understand isn't good for our cams and old engines. Rotella actually dropped their levels as well. Chevron Delo kept the zinc levels at .17 .
- kaw-62046
17 Jun 2007 08:31
www.kendallmotoroil.com/NR/rdonlyres/1FC..._MtrC_4Cycl_MO.pdf.I
am going to use Kendall 20-50.motorcycle 4-stroke oil. It is made by Conocophillips, this is were I work now.So I will give it a shot.
- austin3119
17 Jun 2007 09:07
Grebnaws,
I went back an looked at the delo again . The levels of Phosporus currently is .12 and zinc is .13 which still should be more than fine. The new formulation is the CJ-4 . I think Rotella is about .10 or so for the zinc and phosphorous. A lot of the regular oils now are well well under .10 . The Bob Is The Oil Guy site has a ton of oil tests on the forums where people send in their oil for reviews. Find the oil you like with the most recent review and see what the oil actually contains.
- KawasakiJockey
17 Jun 2007 15:25
kaw-62046 wrote:
I know of only one KZ engine guru and he swears by Kendall oil in these old bikes. He only trusts it as it is the only oil he has ever used that didnt spit shims at high rpm.
www.kendallmotoroil.com/NR/rdonlyres/1FC..._MtrC_4Cycl_MO.pdf.I am going to use Kendall 20-50.motorcycle 4-stroke oil. It is made by Conocophillips, this is were I work now.So I will give it a shot.
- kaw-62046
17 Jun 2007 20:58
I see how everything is made now.As I just started work at a Conocophillips refinery.I will be running Kendell 20-50, 4 cycle motorcycle oil in all my air cooled bikes now.
- KawasakiJockey
