Another for the pros here
  • kzwolfsr
  • kzwolfsr's Avatar Topic Author
13 Jun 2007 13:33
#149048
I have the top end apart and I am working out new shims for my valve clearance. I have a clearance of .004" with 275 shim and spec clearance is 0.28". This is on the 1000. Can someone give me a example of how to work this out?
Original man of the Caribbean
  • RonKZ650
  • RonKZ650's Avatar
Re: Another for the pros here
13 Jun 2007 14:19
#149063
I think you're figuring something wrong Matthew. Generally the clearance you want is about .10mm (.004")- .15mm (.006"). You definately do not want .28" as that is more than 1/4". If you are measuring .004", that's pretty good or you could go to a 270 and be at about .006". I doubt they would call for more clearance than that although I haven't had a bike as "new" as yours for 24 yrs.
  • kzwolfsr
13 Jun 2007 15:16
#149092
My bad, I was reading the spark plug gap measurements! Sorry and thanks Ron! So that means I only have 2 below spec. One is .0025" and the other I didn't have a leaf small enough but the bucket spins. What size shim would I need for that if I have a 280 shim on there now and i need at least .003- .007 spacing?
  • RonKZ650
  • RonKZ650's Avatar
13 Jun 2007 16:10
#149117
If it spins and you've got a 280, a 270 ought to get you perty close.
  • MDawnz1
  • MDawnz1's Avatar
13 Jun 2007 23:13
#149224
To start with ,,,,,,,,
YOU NEED to think METRIC .
Spend the $8.00 to buy a set of metric feeler gauges.(marked with both)
And there are charts posted all over the place with the (? shim change factor ?)
1974 Z1a, still 903
  • wiredgeorge
  • wiredgeorge's Avatar
14 Jun 2007 04:49
#149237
I have examples of how to do the computing on the 903/1015cc Valve Clearances write up on our website. As has been suggested, buy a set of metric feeler gauges. It is much easier to get a feel for shimming with the metric gauges since the shims are metric...
  • kzwolfsr
14 Jun 2007 06:19
#149266
I have metric guys, 2 different readings on one leaf, I just thought since its america......... nevermind!
  • kzwolfsr
14 Jun 2007 06:20
#149267
Thanks Ron and fellow KZRS!
  • tjettim
  • tjettim's Avatar
14 Jun 2007 09:03
#149306
I just use american feeler guages and an
american micrometer.After that it is just
3rd grade math.
  • kawtoy
  • kawtoy's Avatar
14 Jun 2007 11:57
#149356
3rd grade math.
3rd grade math? I'm screwed
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
