valve adjusters
  • udder
  • udder's Avatar Topic Author
valve adjusters
12 Jun 2007 12:42
#148765
i was checking my valve clearance last night and had good measurements on all i think, from .002mm to .004 is the range on both sides most were .002 to .0025. any way i noticed that the valves are shimmed. was just wondering if any models had tappet adjusters i believe they are called???
  • mariozappa
  • mariozappa's Avatar
Re: valve adjusters
12 Jun 2007 12:49
#148767
I believe the KZ440 had the locknut and screw adjusters for the valves instead of shims. I'm not sure about any others. Is that what your referring to?
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
