77 KZ 1000 will only go from 1st to N?
- basscatnc
Thanks,
Mike
- steell
- wiredgeorge
- basscatnc
- basscatnc
Mike
- kzwolfsr
- Thank you received: 16
Original man of the Caribbean
- wiredgeorge
- basscatnc
- steell
IT WON'T CHANGE TO SECOND GEAR WITHOUT THE ENIGNE RUNNING... REPEAT.. IT WON'T CHANGE TO SECOND GEAR WITHOUT THE ENGINE RUNNING...
Uh, yeah it will, as long as the output shaft sprocket is turning it will shift through the gears.
You can put it on the center stand and spin the rear tire by hand and shift through the gears.
Post edited by: steell, at: 2007/06/12 09:53
- basscatnc
- steell
But why even mess with it? We have already explained why you can't shift into second (or higher) unless the bike is actually moving. Just fix anything else that's wrong.
If you are actually riding the bike and it won't shift into second while you are moving, then you have a real problem that we can address.
Post edited by: steell, at: 2007/06/12 10:25
- basscatnc
thanks alot for the replies, eases my brain not worrying bout the gears.
Mike
