Stupid question (oil pan)
  • ScottZ
  • ScottZ's Avatar Topic Author
11 Jun 2007 17:31
#148476
Ok, forgive me, but I am really new and uninformed on 2 wheel wrenching. I recently just stripped out the drain plug threads on my Spectre oil pan. If I'm understanding the flowchart in the manual on bottom end part removal, the oil pan can be removed without pulling the engine out of the frame. Is that correct?
  • The Milkman
  • The Milkman's Avatar
Re: Stupid question (oil pan)
11 Jun 2007 17:34
#148477
Have you checked into just getting a larger self tapping plug and an auto parts store? It will save you a lot of hassle
Ride safe.
  • ScottZ
11 Jun 2007 17:38
#148478
I've thought of it, but have read a lot of posts about people having problems with them. There is a guy locally that will weld and redrill and tap it for $40, but I have to pull the pan and bring it in to him.
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
11 Jun 2007 18:25
#148491
No, you shouldn't have to pull the engine to remove the oil pan. You'll likely need to remove the exhaust system to be able to get to all of the pan bolts though.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • ScottZ
11 Jun 2007 18:45
#148499
Great! Thanks!
  • ScottZ
12 Jun 2007 18:01
#148824
Dang those gaskets are expensive. Anyone know of a good source that doesn't require a $75 minimum purchase? Are there any other options for the oil pan, like a liquid gasket?
  • kawtoy
  • kawtoy's Avatar
12 Jun 2007 18:46
#148841
www.z1enterprises.com . Not sure if they carry Spectre parts but it is worth a try. They are the cheapest and best around
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
12 Jun 2007 19:48
#148867
If you're just needing the oil pan gasket, here ya go:
OIL PAN GASKET
But you better hurry though, there's only about 2 1/2 hours left on the auction! :ohmy:
It would also be a good idea to replace the one large (part# 671B2590, same as used on the oil filter plate) and 3 smaller (part# 92055-077) o-rings while you're in there. ;)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
