Sunken Exhaust Guide-Definition
  • Mcdroid
  • Mcdroid's Avatar Topic Author
  • Gone Kwackers
10 Jun 2007 01:48
#147955
Was just reading another post when I came across a term 'sunken exhaust guide'. What might this mean and what might the problems be associated with this? Thanks.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • BSKZ650
  • BSKZ650's Avatar
Re: Sunken Exhaust Guide-Definition
10 Jun 2007 08:42
#148014
the only thing I can think, is the guide has moved in the head, just a guess
77 ltd1000, current rider
76 kz900, just waiting
  • kawsakiman
  • kawsakiman's Avatar
10 Jun 2007 08:49
#148015
yes.
the guide has moved down about a 1/4 inch.
  • Mcdroid
  • Gone Kwackers
10 Jun 2007 08:50
#148016
Yeah, I guessed that, but if the guide isn't markedly out of place, would that have a negative effect on performance? My reasoning being that what holds the valve in place are the springs/keepers and the stem is relatively long. Can the valve guide be slightly placed differently and still function?
EDIT: and yeah, Steve, it was from your discussion... and if you haven't guessed, I also have a sunken guide:)
Post edited by: Mcdroid, at: 2007/06/10 11:51
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • BSKZ650
  • BSKZ650's Avatar
10 Jun 2007 15:54
#148083
I would want to find out why it has moved, if it goes down that much it can gauld on the bottom of the valve, heat transfer plus the gulde being too far down in the heat path
  • APE Jay
  • APE Jay's Avatar
13 Jun 2007 16:12
#149118
Sounds like the clip came off and letting the guide drop.
As for running them slightly low, no problem. Our guides are made to sit 1 mm lower in the head so that no mater what cams you run, you will not get retainer to valve seal interference.
Jay
  • kawsakiman
13 Jun 2007 19:39
#149171
thanks jay!
but i already sent it out and are having oversized guides installed.
needed 4 intake valves also so bigger stainless ones are being installed.
damm! bigger valves?
now i need some porting work done!
now do we all see the money pit as i do?
the quest for more power is a mighty mistress!
a wise man once told me to spend all my money in the head because
"it can't go if it don't flow"
Post edited by: kawsakiman, at: 2007/06/13 22:41
  • wireman
  • wireman's Avatar
13 Jun 2007 20:27
#149191
kawsakiman wrote:
thanks jay!
"it can't go if it don't flow"<br><br>Post edited by: kawsakiman, at: 2007/06/13 22:41
thats what makes the power,but bottem end keeps it all together:P
