White Exhaust Smoke Reality Check?
- skippr76KZ
09 Jun 2007 12:06
I haven't put a whole lot of miles on my 76KZ900LTD since the engine rebuild - maybe 200 miles. Covered 50 today, probably the longest run I've taken on the bike in one outing. I suspect it's running a little rich. No loss of power, no smell of burning oil. But a fair amount of white smoke - perhaps a very slight blue undertone. Would this be anything to worry about? As if that wasn't odd enough, I noted a couple of strings of fiberglass (maybe a couple of inches) sticking out of the Vance & Hines exhaust holes. At first I thought it was gasket material, but closer inspection showed it to be fiber glass darkened by exhaust smoke. Anybody encounter anything like that with new Vance & Hines (or any) header/exhaust system? Thanks.
1976 KZ900LTD Fully Restored
2000 Vulcan FI Classic
1998 Ducati ST2, Gone
- Duck
- e vica na i sau na ga
Re: White Exhaust Smoke Reality Check?
09 Jun 2007 12:28
It took agood 500 miles of hard riding before the xs650 quit smoking after we worked on it. A good bit of the early on smoke was oil in the pipe from the holed piston
- neilage66
09 Jun 2007 14:20
The fiberglass strips sound like baffle material. Just repacked a Kerker baffle and noticed the same thing after some running the road...looks like the inside of the baffle is a little hairy! :whistle:
- Bluemeanie
09 Jun 2007 16:27
Might take awhile for the rings to seat in, go ahead and just ride it and keep an eye on it. Check your plugs for fuel mixture or oil fouling.
- Muddy
09 Jun 2007 18:17
The fiberglass is nothing to worry about. Its just the packing material from the baffle. When I put my M4's on my TLR it shot fiberglass out of the pipes the first time I started it.
- wireman
09 Jun 2007 18:23
take it out and ride it hard for a while !have you changed the oil yet?;)give me a call before you jump off the roof!
Post edited by: wireman, at: 2007/06/09 21:25
- wireman
09 Jun 2007 18:36
and if that dont work we can always pull it apart and put that 1197 kit in there while we are fixing that pesky oil leak!
- skippr76KZ
09 Jun 2007 19:05
Thanks guys. I feel a little better already. I will keep an eye on it. Man was it a great day for a ride! We really carved up some Ozarks back country roads on the way to the 20th Annual Cape Fair Oink Downs Pig Race. Yep wireman, the engine still has a small pesky leak, but i don't blame my most honored engine rebuild guy. Over all he did a good job. Just as long as I wasn't spittin out gasket material from my exhaust! (instead of baffle material) Hmmm. must have been riding it a little hard! :whistle:
- wireman
09 Jun 2007 19:40
she'll be ok just take her out and put a load on her to seat those rings.now would be a good time to retorque the nuts on the clinder head also now that shes got a few heating and cooling cycles under her belt;)
