Engine Power not good
- dadams7161
- live to Ride Lifes Better on the Road in the wind
it has great pick up but just doesnt on the open roadjust had a thought, does the bike pull hard thru the gears?
1982 KZ750-M1 CSR Twin
3rd Owner of this Jewel
Before and After Photos
- dadams7161
I never thought about the filter since it was the one used by the last guy I will go buy a new one after I get it all back togetherFoam air filter? Hmmm, you may have added so much air, it is actually running out of gas. I would check the throttle cable first (good idea) and then look at the filter second. Does this foam filter require cleaning/reoiling?
- Snakebyte
- Thank you received: 1
These engines are gravity fed and the slightest restriction will leave the bowls dry.
- Snakebyte
- steell
BSKZ650 wrote:
well before the new cluth I was at 4500 now it is around 3000 I believe it is very possible the throttle was not opening all the way I did not check just went ahead and bought a new cable and I just feels like it just looses power when you go up the smallest of a rise in the road it slows down,what rpm are you turning at 55?
since you had a broken cable are you sure you were able to open the throttle all the way?
what does it feel like, is it like it is maxed out or does it shutter like its not getting enough fuel, poss a venting problem at the tank
You changed the clutch and you are now turning 3000 rpm at 55 mph, while before changing the clutch you were turning 4500 rpm at 55 mph?
Are you sure that's right? Can you provide some details like what exactly you changed? That makes no sense at all to me, so I must be missing some info.
There is no way to re-gear a 750 twin to turn 3000 rpm at 55 mph without major modifications, sprocket change won't do it (unless you custom make a 20 some tooth rear).
I currently have three 750 twins, plus another six spare motors, and a bunch of other 750 twin parts. I know the 750 twins inside out.
Just so you'll know that I do know what I'm talking about on 750 twins. I had a 82 KZ750M1 but sold it because I didn't like it.
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- Makarth
im a fan of the clogged exhaust though. stock exhaust on an old bike spells trouble to me
Post edited by: Makarth, at: 2007/06/08 21:14
- steell
I prefer a 17 tooth front and 38 rear on the 750 twins, which is no problem for me as I spend 98% of my time riding solo, it's a bit of a pain riding double with that ratio when taking off from a stop though.
And just replacing the clutch is not going to affect the drive ratios, so the original poster left something out of his description, or is missing something.
- dadams7161
The clutch was bad it had 5 broken friction plates and slipped real bad so I put in a new clutchdadams7161 wrote:
- dadams7161
it is like it is maxed out and I am not sure if the throttle was opening all the way or not I should have it all back together tonight and will test it in the morning.what rpm are you turning at 55?
- dadams7161
