recommended torque
- themachine
recommended torque
07 Jun 2007 17:43
i'v observed that the cam cap bolts should only be bolted to 10ft-lbs, any others that'll snap easily?
head bolts?
oil pan?
cam cover?
pushrod guides?
head bolts?
oil pan?
cam cover?
pushrod guides?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- wireman
- RonKZ650
Re: recommended torque
07 Jun 2007 19:44
Any of the 6mm bolts (10mm head). Like I said before stay at 5 or 6 ft/lb. 10 will strip the cam caps and valve cover bolts.
- themachine
07 Jun 2007 19:55
wireman wrote:
that was a joke to see if anyone was paying attention :silly: :lol:
whats a pushrod guide?:blink:
- Sandy
- Fly High,Tony
07 Jun 2007 21:23
themachine wrote:
Ya REALLY Wireman:laugh:
(I knew that...I really did:whistle: )
wireman wrote:whats a pushrod guide?:blink:
1977 KZ1000 A-1
- KaZooCruiser
08 Jun 2007 07:26
wireman wrote:
I actually saw some of them recently on a Chevy S-10 2.5l motor that the guy wanted me to put a head gasket on.
So they DO exist. Sometimes. On underhead cam, overhead valve motors.
Wireman, you gotta get out more is all.
:lol:
:lol:
- wireman
08 Jun 2007 10:32
KaZooCruiser wrote:
those are guideplates,but ya need pushrods and rocker arm studs for them to mount under;) aint ever seen none on a kaw!wireman wrote:whats a pushrod guide?:blink:
:lol:
- coppertales
08 Jun 2007 11:15
I only torque my cam cap bolts to 100 inch pounds. With a 25 year old bike, the bolts have been removed/installed many times and the threads are weak. Plus, former owners did not know what a torque wrench was and stripped out the bolts. I have had to helicoil all the cam cap bolts on two of my bikes. The other 10mm bolts I only tighten screwdriver tight, I use a nut driver....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- APE Jay
08 Jun 2007 22:03
Don't over tighten the muffler bearing bolt or it can cause a loss of blinker fluid.
Jay
Jay
