81 gpz1100 engine in 77 1000 frame
  • brianrae33
  • brianrae33's Avatar Topic Author
05 Jun 2007 08:23
#146499
anyone know if i'll have any problems fitting an 81 gpz 1100 engine in a 1977 kz 1000 frame??
1982 kz1000ltd
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: 81 gpz1100 engine in 77 1000 frame
05 Jun 2007 09:05
#146511
Do you have them both already?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
05 Jun 2007 09:44
#146519
You'll need to move the motor mounts.
If you already have the frame and engine, I am in Atlanta and have a frame the 1100 will fit and an engine that fits your frame :-) Maybe frame swap?
-Duck
  • racer54
  • racer54's Avatar
05 Jun 2007 15:54
#146622
I've never done this swap personally, but I've read that the J-motors are taller and will be a tight squeeze in a KZ frame up near the backbone frame members under the tank. Guy said something about either mounting motor into frame without the head installed or couldn't remove head with motor in frame, or some such thing. Like I said, not an expert on this swap but just wanted to add what I heard about this swap.
  • brianrae33
05 Jun 2007 17:26
#146645
actually have the entire '81 gpz1100..but no title..was told it's a real pain in the ass to get a salvaged title..so figured i'd just buy a frame with a title...
1982 kz1000ltd
  • steell
  • steell's Avatar
05 Jun 2007 20:37
#146726
There is or was a member that put a GPz1100 motor in a 83 GPz750, so I imagine that putting the 1100 in the 77 1000 frame would be a little simpler.
