Kooler Kontrol and Earl's...any info?
  • neilage66
  • neilage66's Avatar Topic Author
04 Jun 2007 15:17
#146257
There is a "Kooler Kontrol" on the oil cooler of my KZ1000. I found out it was patented in the late 70's by some California guys...the bike is an 1980. It apparently acts just like a thermostat in the cooling system of a car, except for the oil. It's attached to a pretty big cooler with red Earl's fittings. Earl's is still around and sold at places like Summit for example. Don't know if the cooler could be Earl's or Lockhart either?
Anyone hear of this brand / device?
What can you tell me?
I got 2 pics for ya. :)
Post edited by: neilage66, at: 2007/06/04 18:19
  • neilage66
Re: Kooler Kontrol and Earl's...any info?
04 Jun 2007 15:17
#146259
2
  • neilage66
04 Jun 2007 15:19
#146261
3
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
04 Jun 2007 19:00
#146324
Sorry bud ,never seen 1 before,but its a great idea.if u find out where to get them or how to make 1, let us know.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • neilage66
04 Jun 2007 19:26
#146331
Thanks for looking.
Here's the poop on the patent (short version) :laugh:
Earl’s Fittings owned by Holley?
Kooler Kontrol owned by Kerker?
Patent 4027643
Inventors: Feenan; Patrick J. (Northridge, CA), Walton; Edward B. (Marina del Rey, CA)
Appl. No.: 05/604,560
Filed: August 14, 1975
United States Patent 4,027,643
Feenan , et al. June 7, 1977
Title:
Oil cooler control
Document Type and Number:
United States Patent 4027643
Link to this page:
www.freepatentsonline.com/4027643.html
Abstract:
An oil cooler control for the cooling of lubricating oil especially advantageous for engines of relatively low horsepower operating at relatively high R.P.M. makes use of a thermal responsive bypass valve device for altering the path of oil circulation over a cooling coil. The valve device has a valve chamber with a valve seat intermediate opposite ends and a valve element cooperates with the seat in response to a thermal drive element. When the oil is cool most of the oil is passed from the engine through the chamber and directly back to the engine. As the oil temperature increases the valve element is seated causing the oil to be passed through a cooling coil and then back to the engine.
  • steell
  • steell's Avatar
04 Jun 2007 19:46
#146346
Oil thermostats for oil coolers are pretty common and readily available, just search on Google and you will find a good selection of them.
I don't know anything about the one pictured though.
  • Paling1
  • Paling1's Avatar
05 Jun 2007 02:31
#146421
Look at the pics in this German forum:
click
there are som pics of oilthermostats. Racimex and Mocal are the brands. The Racimex looks a lot like the 'Kooler Kontrol'.
One of the big advantages is a faster warmup of the oil, which is usefull if you regularly drive short distances.
KZ700-A1 (1984)
525 chain conversion; Dyna 2,2 ohm coils; Taylor plugwires; Stainless steel ZR-7 exhaust ; Remus muffler.
Plans: GPZ cams, ported head, 17 inch wheels, EFI....
