Valve Shims
  • baldy110
  • baldy110's Avatar
Re: Valve Shims
18 Feb 2016 09:00
#711288
So you haven't been riding the bike in over 8 years, Wow I feel sorry for you.
  • aenikolopov
  • aenikolopov's Avatar
Re: Valve Shims
18 Feb 2016 10:05
#711299
baldy110 wrote: So you haven't been riding the bike in over 8 years, Wow I feel sorry for you.
Hah - no! The thread was started by someone else, 8 years ago. I had a question on the same topic, but about a bike that I bought half a year ago. I'm keeping it in the same thread because I had a question about something that was posted in this thread 8 years ago.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Valve Shims
18 Feb 2016 10:34
#711304
The problem with using old threads, some of the pics will have timed out.
  • Olajoe
  • Olajoe's Avatar
  • Free at last
Re: Valve Shims
18 Feb 2016 10:47
#711306
Gather all the information you can so that however this turns out you are comfortable with the results. That's the main thing, You don't want to be riding having second thoughts on whether or not you did it right. Take ownership. Trust me, there's always going to be a better way, a more precise way that is more efficient, effective, you name it. In understanding valve shims you'll determine the best way to approach this. However process you choose main thing you can sleep with it and just keep it to yourself. This is the key part right here -yourself-, or be prepared to defend your method. It's the nature of the beast very much so when it comes to things that may propel you from here to there.
The following user(s) said Thank You: aenikolopov
  • aenikolopov
Re: Valve Shims
24 Feb 2016 15:34
#712359
Thanks all for the suggestions. Was able to adjust valves one camshaft at a time. 3 valves were off, and though they were all off by just about 0.02mm, (so, i was measuring about 0.06mm), going down a shim in each got rid of a noise I had noticed recently, and the bike does seem to be running better.
