head bolt washers, any substitutes?
- themachine
02 Jun 2007 12:34
i was counting my headbolts and i noticed i only had 10 headbolt washers and that only 3 of them appeared to be copper or copper coated, the rest are silver, none appear to be squished in any way.
is it possible to just use a standard steel washer under the headbolts?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- tjettim
Re: head bolt washers, any substitutes?
02 Jun 2007 13:10
Only the outside four are copper.You
will want copper there.
- themachine
02 Jun 2007 13:16
anyone know where i can get one more copper, z1 doesn have it listed?
- wireman
02 Jun 2007 13:38
try an auto parts store,you need to anaal the other 3 before using if they are used;)
- Garn
02 Jun 2007 13:49
I have purchased them from Kawasaki...Part Number 92022-215 (Washer, plain,10mm).
As Tjettim says, you really only need the four outside ones to be copper. However, the Z1 series had all 12 copper. It wasn't until the later Z1000's that they changed to steel, still leaving the copper for the four outside, so as to seal the oil-way to the head.
They appear to be a standard 10 mm washer. I have used brass (softened by heating to cherry-red & quenched) on the eight inner.
RegardZ.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Sydney Australia
- APE Jay
- themachine
02 Jun 2007 14:08
nuts, head nuts, LOL! oops
- tjettim
02 Jun 2007 15:22
Kawasaki gets over 6 bucks for one.
Anyone want to tool up and make washers?
