piston pin c-clips
- themachine
piston pin c-clips
02 Jun 2007 10:33
any special method or tool you guys use to get the c-clip for the piston pins in?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- kawtoy
Re: piston pin c-clips
02 Jun 2007 11:13
No special tools or method. If you are doing it on the bike make sure you put rags in the open cylinders in case you drop one of them. I learned that the hard way. Luckily the clip fell right into the oil pan and I got it out no problem.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- RetroRiceRocketRider
02 Jun 2007 11:17
I know I'm going to state the obvious here, but be EXTREMELY careful in using that whatever tool you're planning on using so that it doesn't scratch/gouge the sides of the pistons. :pinch:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- themachine
02 Jun 2007 12:18
nevermind, i used my shim changer prybar to stick em in.
- cuddies
02 Jun 2007 15:27
I've used a small pair of needle nose pliers my whole life. Never caused any problems, and can get them in in about 20 seconds.
