I used it in a car that would pop through the throttle boy under hard exceleration. I hooked up a can to the vacume port and had the engine stall out and sit for 5 min. When I started the car the engine smoked really bad for a minute then cleared up. No more popping through the throttle.
Great stuff I use it in every thing.
The best way to add it is hooking up vacume lines to intake boots then connect them into a bigger vacume line in the can. Start the bike keep it running at high rpm till 1/2 can then rev it and snap the throttle closed with the ignition off. When it stalls the valves and piston will dranched in sea foam. Let it sit for a min then start up the bike and runn the rest of the can dry.
Its gonna smoke like crazy. After the engine cools look inside the cylinders and you be the judge.
