BS help needed. . .
- KaZooCruiser
BS help needed. . .
30 May 2007 16:39
. . .now that I have your attention.
The only thing in common with a KZ is that it has a battery, tires, and an engine. Which is what I need help with.
Here is the sorry thing before I bought the expensive battery and blew up the motor:
I know, I know, you are saying by now, "what does this freaky looking thing have to do with a KZ?"
Well, without a service manual, I don't know what the spec is supposed to be on the main journal. I don't have one. But maybe someone out there in KZ land has some access to help me.
It's a Briggs & Stratton 12 horseposwer.
:laugh:
Model number:
281707
Type:
0144-01
Code:
87102411
The only thing I got from the non-helpful ACE small engine guy was that he thinks I need to buy one of his shortblocks for $380.00, because it's a 20 year old motor.
Well, golly, I have a 30 year old 650 motor that runs just fine, thankyouverymuch.
Wasn't much trash in the pan for 20 years. I can get another aluminum connecting rod.
I just need to know what minimum main journal should be at this point.
Thanks in advance.
:laugh:
Model number:
281707
Type:
0144-01
Code:
87102411
Thanks in advance.
- BSKZ650
Re: BS help needed. . .
30 May 2007 17:31
dont waste your time trying to rebuild it, cheaper to buy a new short block, been there done that.
77 ltd1000, current rider
76 kz900, just waiting
- KawasakiJockey
30 May 2007 17:52
I have a B&S service manual here. I will go find it and get the info for you.
- KawasakiJockey
30 May 2007 18:03
My book is a from Nov. 1976.
You want the rod journal size not the mains, right?
Post edited by: KawasakiJockey, at: 2007/05/30 21:05
Post edited by: KawasakiJockey, at: 2007/05/30 21:11
- wireman
- BSKZ650
31 May 2007 05:20
The last one I killed, by the time I looked at all the parts I needed, crank, rod, piston ,rings, gaskets, it was cheaper to buy a short block ready to go, not to mention the time to rebuild it
- KaZooCruiser
31 May 2007 12:07
KawasakiJockey wrote:
The main is the end that has all the aluminum transfer on it. Once I use muratic acid to clean off the aluminum, I need to measure it.
The small end (wrist pin and piston) are fine.
I need to see if the crank is within salvage.
Thanks
My book is from Nov. 1976.
Thanks
- wireman
31 May 2007 13:31
if the crank isnt mauled and rod cap isnt destroyed just have the rod resisized.or ask harry williams about making a babbit bearing insert if you really feel creative!
- themachine
31 May 2007 16:34
i had one of those, sold it for 35$ in good mowing shape, however it would throw the belt every once in a while.
stick in a kz650 motor and enjoy your one wheel peels.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
