crankcase breather filter
  • tcbradbury98
  • tcbradbury98's Avatar Topic Author
28 May 2007 19:02
#144386
So I put pods on my bike and put a breather filter on the crankcase vent. I'm have a little oil blowby through the filter. Is it because the filter is so short? What has everyone else done with the crankcase breather when converting to pods? I figure that part of the issue is I may have put too much oil in when I changed it last week. Will drain and refill, but what has everyone else done? thanks
  • tcbradbury98
Re: crankcase breather filter
28 May 2007 19:31
#144407
Well I guess I should have searched a little more, I am gonna dreain and refill the oil and put an extension hose on the filter. Ideas are still welcome.
  • JR
  • JR's Avatar
28 May 2007 19:51
#144412
I have K&N pods on the carbs and a little K&N crankcase filter right on the crankcase vent - no extension tube. No problem and no blow by.
Hopefully refilling the oil to the correct level will work for you and resolve the problem.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
28 May 2007 21:47
#144437
Ditto.B)
1977 KZ1000 A-1
  • mrbreeze
  • mrbreeze's Avatar
28 May 2007 23:18
#144449
You really don't need a filter on it... just take a foot (or so) of heater hose and run it down in front of the swingarm.
That way nothing can fall or drip in and nothing is going to splash bad enough to travel a foot (or so) up that small hose.
I have ran mine like that for years.
I did find a picture... it was actually of the oil cooler lines, but I think you can get the general idea.
