KZ 650 B
- skydailey
KZ 650 B
27 May 2007 09:45
Whats the diff. between the 650B and the other 650 makes. I see like 650c and d's?
- anarki650
Re: KZ 650 B
27 May 2007 09:54
650B has single front disc brakes with rear drum and spoke wheels instead of the C's dual front/single rear disc with mags. The D models are the SR models which don't have the rear duck bill tail section and have a different tank style and side covers than the B and C's. Different years received different model designations and I'm not familiar with those past the D model.
B models were made from 77-79 (if I'm remembering correctly).
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- skydailey
Re: KZ 650 B
27 May 2007 10:04
Awesome! So wich of the three listed were so to speak lower end or inferior to the other?
- OKC_Kent
Re: KZ 650 B
27 May 2007 10:50
None were inferior my boy, none at all.:laugh:
I guess the B is the standard no frills model. C is one up the ladder, D is about equal to C, just a different look.
Cashion, OK
78 KZ650 B2 85,000+ miles
- N0NB
- Blue handles better
Re: KZ 650 B
27 May 2007 11:51
All shared the same engine, so no difference there. The SR (D model) has crossed pipes which feed 1 and 4 exhaust to the right and 2 and 3 to the left. There is some debate about what this did, alter the sound and I'm not at my FSM, but I seem to recall the SR having a couple horsepower less than the other and a flatter torque curve.
A lot of parts interchange between the models until the frame and body work and then the D has different pieces. Interestingly, the tanks will interchange.
A lot of 650s were brought and built here and parts have been plentiful. But that's changing as a couple of front master brake cylinder parts for the SR have been discontinued (fortunately, I didn't need them). So, in the future some alternatives may be necessary.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- anarki650
Re: KZ 650 B
27 May 2007 13:18
The SR (D model) or C models have a better brake system than my B model (but with a cross drilled rotor on the front of the B I've had NO issues with stopping power), but other than that you'll be hard pressed to make any claims of superiority between models. It all ends up being which you prefer visually (in my case I love the classic look of the spoked wheels on the B model, so I compensated for the braking system with a little upgrade).
09 Kawasaki ER6n
Omaha NE
Omaha NE
- skydailey
Re: KZ 650 B
27 May 2007 13:30
one more thing? Is there an aftermarket exhaust that just make these things sound ultra tough?
- anarki650
Re: KZ 650 B
27 May 2007 14:29
There are several aftermarket exhausts that sound awesome. I've got the Mac 4-1 running w/ no baffle on mine and it sounds freaking amazing. Warning though, if you pull the baffle your neighbors WILL hate you!
Vance and Hines make an aftermarket as well as several other companies. Pretty well any 4-1 exhaust system will make these 650's purr, and if you pull the baffles out of the pipe that purr turns into a beastial roar!
09 Kawasaki ER6n
Omaha NE
Omaha NE
- rstnick
Re: KZ 650 B
27 May 2007 16:09
You can get more info on the 650 models here
www.kz650.info/
and here
z650
Post edited by: rstnick, at: 2007/05/27 19:10
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- skydailey
