Engine Forum
Engine forum is a tech forum for "Engine" topics.
Oil cooler removal on kz1000
  • Bob_79KZ
  • Bob_79KZ's Avatar Topic Author
26 May 2007 22:07
#143849
I have a 79 KZ1000 ST and I want to return it to box stock condition. It has a small oil cooler installed and I'm not sure how to un-install it. Below is a pic of how the line are set up going to the cooler.
Do I just remove the hoses and put plugs where the hose barbs are? Or do I run a line from one hose connector to the other? My manual does not show pictures of the oil galleries so I want to be sure I don't cut off the oil to anything.
I looked in the archives but could not find an answer.
Thanks for any help offered..
Bob
Post edited by: Bob_79KZ, at: 2007/05/27 01:09
Post edited by: Bob_79KZ, at: 2007/05/27 01:11
  • donthekawguy
  • donthekawguy's Avatar
Re: Oil cooler removal on kz1000
26 May 2007 22:14
#143850
You will have to find an oil sensor housing. The Parts that the lines hook to will have to come off and the housing will go on. The housing is a one peice unit so it takes up both oil passages and all four bolt holes. I don't have a pic but I'm sure someone will post one up soon.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Bob_79KZ
26 May 2007 22:22
#143857
So, just hooking a hose from one connector to the other would'nt work?? I know, it would be ugly...but it should work, I think.
Thanks for the reply...I'll start looking for the part you mention.
Bob
  • donthekawguy
26 May 2007 22:46
#143865
It'll work but why not just leave it on until you find the right part? Cooler oil don't hurt.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
26 May 2007 23:32
#143869
Bob,I would say put the factory pipe/switch back on there,Bud.Without the switch,You have no "Low oil" warning light.
I have one here,and if You're interested,We could swap?
I WAS going to send it to Don,but He got one elsewhere.
Let Me know if You're interested.B)
1977 KZ1000 A-1
  • kaw-62046
  • kaw-62046's Avatar
27 May 2007 10:47
#143948
If you need one let me know.I have all kinds of Z1,KZ900,KZ1000 engine parts that I am closing out.I have been dealing in these bike for over 25 years.Making room, as all my storge is full, Do not have time these day to put all these bike back together.Thanks mark
