electric shifter
- wireguy
electric shifter
23 Dec 2005 16:14
my local carb hero was telling me about a pushbutton shifter that uses an electric solenoid instead of compressed air to shift transmission,he said it has its own little computer brain that kills the ignition for a split second while it shifts.anybody heard anything about this system?ill see if i can get the name from him.
- wireguy
Re: electric shifter
23 Dec 2005 16:57
i think he said it was made by pingle,does anybody know how to find their website?
- hwms
23 Dec 2005 17:47
I know some of the Goldwing riders use something like this but I do not know the make and/or source.
Harry
Harry
- wireguy
23 Dec 2005 18:01
i got on pingles website,theyre pretty proud of em $800.00 i think i can scrounge enough parts together for an airshifter for less than that,ive got a calfab swingarm with an airtank built into it i bought 20 yrs ago thats never been used i think thats the way im going!
- loudhvx
23 Dec 2005 20:20
Wouldn't that cause a backfire at the shift?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- RacerZ
23 Dec 2005 21:01Please Log in or Create an account to join the conversation.
- wireguy
24 Dec 2005 09:36
dale walker isanother name i havent heard in a long time has built some really fast stuff over the years,did anybody notice the 9 second 1170 honda with the 29mm smoothbores?smaller carbs really do work!
- 77KZ650
24 Dec 2005 21:19
I saw something like this on OCC one night, the one where they made the yellow drag bike. I'm not sure if it was an electric or air shifter, but it did kill the ignition for a split second so the clutch didnt have to be used, and/or you didnt have to manually let off of the gas.
07 MDP Rookie of the Year
- romzrx
28 Dec 2005 17:31
Check Dennis Kirk catalog page 512 universal electric shift kit $650. from Pingel.I preferred the air shifter its cheaper to built, a friend of mine has one on his BUSA and I used couple of times.You need to get a small air compressor with a small tank,pressure gauge, two switches and a small air piston (Bimba valve) and some electical parts that will cut your ignition off.
76 KZ900
79 KZ1300
82 KZ1000J
C10
C14
ZRX1200
79 KZ1300
82 KZ1000J
C10
C14
ZRX1200
- wireman
30 Dec 2005 08:08
i have a cal-fab swingarm with an airtank built into it,but i was also thinking about using the frame tubes as an airtank.im trying to avoid using an air compressor takes up space and extra weight now that im not 126 anymore (getting closer to 206!haha)i want to keep this bike as light as possible!
- kzcory
30 Dec 2005 08:20
You can use a large CO2 tank normall used for paintball guns. They last quite awhile and can be refilled.
- wireman
08 Jan 2006 11:51
my local carb hero came up with a plan for an electric shifter but were still in the planning stages it will all be concealed down low without all the extra wiring or air lines of a regular shifter,in fact you wont even know its there!as soon as we get the first one figured out i get a picture posted of it!
