if there is no grooves worn into housing or top/bottem of gears i would glue a piece of fine sandpaper to something flat like a piece of glass and rub the mating surfaces of pump body across it a few times and recheck your clearances,you might need to do it a few times;) (i should write romance novels!:blink: :S
)thats how i blueprint stock pumps;)
