fuel tank cleaner?
- KingOfBoggle
fuel tank cleaner?
24 May 2007 09:31
hi all,
this might not be in the right forum but it seemed the most appropriate overall to me. i've got a '79 kz400 that i am trying to fix up. it's been sitting in the garage for close to a year with a full tank of gas in it. last night i took off the tank and got all the old gas out of it. i can hear tiny little items in the tank when i shake it. it sounds like little pebbles are in there. there is some noticeable rust in the inside of the tank as well when you open the top with the key. should i do anything about this, and if so, what exactly? is there a cleaner i should use before i put fresh gas in?
thanks so much for the help!
- mariozappa
Re: fuel tank cleaner?
24 May 2007 09:35
There is an article in the filebase to take care of this problem.
kzrider.com/component/option,com_docman/.../gid,248/Itemid,231/
1977 KZ650C1
and the KZ650/KZ750 Conversion
- KZQ
- Administrator
24 May 2007 10:12
Hi Guys,
Speaking as a member only!
I've got to say that phosphoric acid will take days to do what my system will do in a couple of hours. Additionally, my method doesn't require so much mechanical abrasion to get rid of the scale.
Check out my article at: kzrider.com/content/view/22/11/
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- mrbreeze
24 May 2007 12:17
Very nice article you have there KZCSI.
I used Kreem on my older bike back in '89 or '90 and except for a little darkening due to age it’s still in good shape.
I do worry, ok wonder what happens when a Kreem job finally goes south. At that point I guess the tank would have to be split if you couldn't find another.
- kawsakiman
24 May 2007 20:56
one gallon simple green.
fill dry tank with it.
add boiling water.
let set overnight.
empty tank.
smile.
only works on light rust.
not a sat open for ten years rusted tank.
Post edited by: kawsakiman, at: 2007/05/24 23:57
add boiling water.
let set overnight.
empty tank.
smile.
- Fourtoes
- N0NB
- Blue handles better
31 May 2007 04:43
mrbreeze wrote:
The POR-15 people have a cycle tank repair kit that contains an extra chemical that is supposed to dissolve failed tank sealers (presumably Kreem).
Fourtoes, Simple Green is a non-toxic, biodegradable cleaner that works quite well on grease. Yes, it's green in color.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
