turbo help again, spray???
  • jordan
  • jordan's Avatar Topic Author
23 May 2007 22:14
#142996
Me again looking for more help with my turbo project. I was looking at some other projects and thought, why not add a little laughing gas(nitrous)haha. I thought maybe that the nitrous would help the motor spool up the turbo so there wouldnt be near as much turbo lag. With a blow through system i would have to mount the nitrous plate between the carb, and the turbo. Would this work? Would the nitrous burn up inside the turbo?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • 77KZ650
  • 77KZ650's Avatar
Re: turbo help again, spray???
23 May 2007 23:00
#143006
first off, are you doing a blow thru single carb or draw thru single carb?
nitrous wont actually burn, it lets you burn more fuel. its a nonflammable gas that when serious pressure is applied (compression stroke=over 100psi easy) it breaks up into oxygen and nitrogen, the nitrogen acts as a buffer that helps prevent detonation and carries a lot of heat out of the engine, which is why straight oxygen (O2) isnt used.
i would think it should be fine to spray it into the turbo, its the same as a draw thru setup, its just air and fuel if you think about it, the air is just colder. it really shouldnt go kaboom if setup properly(as in dont try a 150 shot) and your turbo doest have sparks in it:woohoo: (you would have a few problems if it did to say the least as you know:silly: )
07 MDP Rookie of the Year
  • themachine
  • themachine's Avatar
24 May 2007 03:17
#143024
from my understanding it is bad to use the juice on a, forced induction motor because it promotes knocking.
and from what i'v heard its an even bigger b#$^@ to tune it so it doesnt f$%# your motor up than usual.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • wireman
  • wireman's Avatar
24 May 2007 04:32
#143030
aint no big deal;)
  • 77KZ650
  • 77KZ650's Avatar
24 May 2007 18:56
#143240
wireman wrote:
aint no big deal;)
yup, contact APE www.kzzone.com they should be able to help. another place to check out is the forums on www.dragbike.com
  • 77KZ650
  • 77KZ650's Avatar
24 May 2007 19:01
#143242
its great to help kill turbo lag if you have a big turbo designed for high rpm (especially if its carb'd)
no boost yet? hit some compressed gas to speed things up:evil: :whistle: just dont keep it going under full boost, then its a problem, an explosive one:pinch: :sick:
definatly have someone with a dyno tune it
