I am gonna be putting in a set of Kz750 cams into my 77 Kz650. I'm sure the cam chain prob stretched over the years a little so I am gonna throw a degreeing wheel on there and check everything out just to be sure. I'm not afraid to slot the cam sprockets a little if the timing needs to be changed. So... What is the correct lobe centers supposed to be on these cams? I have heard 105 degrees on int and exh but I just want to be sure.
Thanks,
Eric
1977 Kz650B1 #576th made.
Warsaw, In
