Oil cooler pics
- bkitchen
Oil cooler pics
22 May 2007 10:23
Anybody have any pics of there bikes with an oil cooler installed? Just want to see where you routed the lines and such. Thanks
- JMKZHI
Last edit: 03 Dec 2008 10:53 by JMKZHI.
- rstnick
Re: Oil cooler pics
22 May 2007 12:54
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- bkitchen
- kawtoy
Re: Oil cooler pics
22 May 2007 13:48
Mine run over the valve cover. I was thought about running them under the engine but decided that they could easily be cut by a rock or some other debris.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- duncan
Re: Oil cooler pics
22 May 2007 14:20
you might want to check out the pics at
www.a-magic.com
Post edited by: kzrider, at: 2007/05/22 17:28
- mrbreeze
Re: Oil cooler pics
22 May 2007 14:40
Mine go over the top and down between the air filters.
Post edited by: mrbreeze, at: 2007/05/22 17:49
- mrbreeze
- Sandy
- Fly High,Tony
Re: Oil cooler pics
22 May 2007 15:53
mrbreeze wrote:
That's exactly how I have Mine routed,btw.
I bought a 6 foot length of steel braided line(pre cut and packaged)...tested first with a standard line before cutting the S.B. line($$$),to check for length on each line,and the 6 foot length was a perfect match...nothing discarded.It was tight though,so You'll need at least 6 feet,if You want to route them under the tank.
1977 KZ1000 A-1
