Clutch Won't Disengage
- Norseman
22 May 2007 08:42
I really need some help here - my clutch won't disengage. Good tension on lever, cable moves free, adjusted clutch release on crankcase and cable adjusters per factory manual, but to no avail.
It worked fine when I started working on carbs and returning to airbox system from pods, and did the valve clearance. Bike runs great now, but the clutch won't disengage.
The bike shifts between gears fine without engine running (obviously can't test when running).
I need to get the bike running asap, and need some guidance on what to do and where to start. I'm desperate!!!
- kzwolfsr
Re: Clutch Won't Disengage
22 May 2007 18:40
Ok Norseman Open the oil cap and look inside and see if the clutch loosens up when you disengage the clutch.... You may need to use a screw driver to touch the plates and check to see if they move. If not the clutch is not ajusted off the flywheel enough, IF you haven't done it right!
Original man of the Caribbean
- kzwolfsr
22 May 2007 18:41
Also I trust you have all the bolts tightened on the sprocket cover!
- Norseman
22 May 2007 20:37
Thanks, kzwoldsr, they are separating and actually works now. I think the problem was the plates were gummed together. When I checked the oil level, I noticed it was way high, so I drained the oil. What I got out was 5 quarts of liquid. The oil had a very strong gas odor with viscocity not much more than water, so I assume the bike must have sat for a very long time with the petcock open (non-vacuum, after-market) allowing more than a quart of gas to drain into the crankcase. Either that or the PO over-filled the oil by a significant amount.
However, just before shutting it down, the clutch finally kicked in, so there it is... Thanks again for responding!
- Norseman
