head gasket size?
- brawnyrebel
head gasket size?
21 May 2007 17:56
I am putting the head on my 76 900ltd and the metal rings on the head gasket are slightly smaller than the cylinders. Is that normal? Also is there a trick to getting the cam chain to catch on the bottom sprocket or am i doing something wrong?
Post edited by: brawnyrebel, at: 2007/05/21 20:57
- wireman
Re: head gasket size?
21 May 2007 21:40
you dont want gasket hanging into cylinder.chain can be a real bitch,grab hold and keep working it;)
- Sandy
- Fly High,Tony
21 May 2007 22:03
You want the bike to be vertical,and not on the kick-stand,when You're trying to get the chain to catch the crank.
1977 KZ1000 A-1
- mark1122
- Keep twisting it
21 May 2007 23:38
They got ya covered rebel.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 77KZ650
21 May 2007 23:45
if the head gasket is sticking out into the cylinder, file/dremmel it to the right size
do you have a manual?
07 MDP Rookie of the Year
- tjettim
22 May 2007 03:27
If this is a composite gasket with the
metal compression rings around the bores
do not mess with the ring part.You will
need an oversize gasket to match your bore.
Check your bore size and make sure you have
the right gasket.
the right gasket.
- kzwolfsr
22 May 2007 18:19
Did your cylinders have a bore job you don't know about and you just happened to get the stock gasket? Check the size of the cylinders and look up the stock size to see what happened.
Original man of the Caribbean
- brawnyrebel
22 May 2007 18:32
I bought a 900 gasket kit when i started the build and decided to go to a 1015 top end. I was told it would work but it did not look right so i am going to order a set of 77-78 kz1000 head gaskets
Post edited by: brawnyrebel, at: 2007/05/22 21:33
