No oil pressure ???
- 84kz700
No oil pressure ???
21 May 2007 16:26
I just built my KZ700 engine after it spun a rod bearing and now there's no oil pressure. The oil pressure light is on below 4k rpm and we tried putting another oil pump in it and now the light is on solid. I tried taking out the oil sending unit and no oil comes out of the hole when turning the engine over. What else could it be?
- 84kz700
Re: No oil pressure ???
21 May 2007 18:44
Is there a way to maybe "prime" the oil pump or something.... I just put the pump in and fired the bike up seen it had no pressure and shut it off (dont want to run it with out oil pressure)
- steell
21 May 2007 19:51
Take the spark plugs out and spin it over with the starter, if the light don't go out in a few seconds then you have a problem.
Did you clean out the oil passages?
The main cause of spun bearings is lack of lubrication.
- mark1122
- Keep twisting it
22 May 2007 07:45
DID YOU CHECK THE CLEARANCES IN THE OIL PUMP?cHECH YOUR MANUAL AND SEE IF THERE IS A PROCEDURE.(SORRY ,CAP LOCKS)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- BSKZ650
22 May 2007 11:09
why did it spin the bearing in the first place?
good possiblity that you had a oil pump problem already
77 ltd1000, current rider
76 kz900, just waiting
- 84kz700
22 May 2007 12:20
but I put two other pumps in it....Yes I did make sure the oil "orphes" (no clue on the spelling) were clean well out to the garage to play with it somemore..... oh and I dont know what you mean by "did I check the clearance"
THX
BLAIR
THX
BLAIR
- BSKZ650
22 May 2007 13:22
if you look in the manuel you will find the specs for the oil pump.
also check to see that the relief valve is not stuck open
- 84kz700
22 May 2007 14:45
What exactly do you do with the relief valve? I think I found it and it has a ball bearing thing in it. Is this it?
- 84kz700
22 May 2007 17:37
Well I figured out the no oil pressure problem!
When I tore the original motor apart I found a ball bearing, spring, washer, and cir clip in the oil pan well I didnt think anything about and on the new motor I used the same oil pan!!! It just turns out that those 4 things are the insides of the relief valve!!! Well now I know why my original motor spun a rod bearing!!!
THX EVERYONE YOU GUYS HAVE BEEN EXTREMLY HELPFUL TO ME!
BLAIR
BLAIR
- kzwolfsr
22 May 2007 17:52
Mark meant check clearances by using a feeler guage to see how much clearance is there between the teeth of the gears in the pump and the wall these teeth contact in the pump. Also the teeth contact clearnce between the teeth of both gears. But good to see you found your problem.
Original man of the Caribbean
