Clunking noise in KZ Belt Drive
- Tyler
20 May 2007 16:46
My bike clunks when I take off from a stopsign, etc. I can also hear it when snapping the throlttle at low speeds. I thought it was the rubber isolator in the rear wheel but that is not the case. With the rear wheel of the ground and the bike in gear I can move the belt back and forth about an inch, I am concerend it may be a problem in the transmission:unsure:, the primary is new.
IF this is abnormal what could be worn in the transmission enough to cause this? The bike has 13k on it.
"74 Yamaha DT 400 Enduro
- kzwolfsr
Re: Clunking noise in KZ Belt Drive
20 May 2007 17:10
Hey Tyler that is normal for the bike to be able to move back and forth in gear like that. But I am now experiencing the same problem at take off with my bike. Do you experience a rotational rough spot sound when rolling with the clutch disengaged? Also does the noise sound like it is underneath you and happens when you apply the clutch and just a small step away it clanks, not once but twice to 3 times til you get a steady roll? If yes to these questions, I suspect that the spacer/ washers in between 1st gear and the bearing on the out put shaft is below spec and the gear has alot of side to side play, and goes diagonally at times. I just took off my oil pan the other day and that gear was a little rocky, like a loose tooth Help for the both of us!
Original man of the Caribbean
- Tyler
20 May 2007 18:53
This is on my 440 and as far as I know I have to take the engine apart just to inspect it. My bike only clunks when I take off or let-off. A repeating noise like you describede is never a good thing...
Don't know if this is a normal thing...
the kawasaki clunk...
- kzwolfsr
20 May 2007 20:22
It is this small bearing type noise so I changed the bearings in my rear wheel and still I hear that noise
- tjettim
21 May 2007 03:21
Does the 440 engine have a primary chain?
On the the British twins loose primary
chains would make noise.A worn or loose
cluth hub can make noise also.
- Tyler
21 May 2007 06:25
yes there is a chain primary on the 440 but I have replaced it. It was making alot of noise and one of the guides had broken. The clutch was in great shape when I looked at it.
- Tyler
21 May 2007 08:04
- Tyler
21 May 2007 08:23
- flht1997
21 May 2007 08:36
did you check the countershaft sprocket to make sure it is tight?
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
