small hole in my crankcase
- georgeha
17 May 2007 19:12
I had the chance to do some wrenching today, trying to track down an oil leak. I had hoped it was a leak from my dynamo shaft, something easily remedied with some cheap O rings from Harbor Freight.
When I took off the dynamo cover, I saw this little hole in the crankcase/block joint.
I imagine the best thing to do is take everything apart, fix it and put it back together. Do I have to, can I patch that with JB Weld or solder something there?
I did get it started at least, first start of the year.
Thanks
George
Post edited by: georgeha, at: 2007/05/17 22:17
Thanks
George
- steell
Re: small hole in my crankcase
17 May 2007 20:18
Was this hole a casting flaw, or was it caused by something breaking the case?
I have a 750 twin motor with a casting flaw that leads to the oil gallery right above the points cover. It was a constant oil leak until I sealed it up with epoxy (same as JB Weld).
- Sandy
- Fly High,Tony
17 May 2007 20:19
Pics?...:whistle:
Close-ups if You can.
1977 KZ1000 A-1
- georgeha
18 May 2007 06:10
My laptop died last night before I could properly resize a pic, I hope this one works.
I had never noticed the hole before, but last summer I started to get a fresh oil leak from the front sprocket area, and noticed fresh oil in the dynamo area.
Post edited by: georgeha, at: 2007/05/18 09:11
