Engine Forum
Engine forum is a tech forum for "Engine" topics.
Engine rpm related to actual mph?
  • barquirt
  • barquirt's Avatar Topic Author
15 May 2007 19:11
#140447
OK strange question of the night...
I have a 1977 KZ650B1 I've been rebuilding for the past year or so... it is mostly stock, mild cafe mods like low bars and bar-end mirrors but little messing with the mechanicals. I do have pod filters and I've got the jetting pretty dialed in. It has a new chain and sprockets (16T front, 42T rear) and new tires as well.
Now then... as I buzz down the road in town I hit 30mph or so at 4,000 rpm in second. I can puddle along at 30 - 35 mph in third at 3,000 rpm or so. On the highway in top gear (fifth) I'm doing 60 or 65 at 4,000 - 4,500 rpms. I have a 9,000 rpm redline. The sprocket sizes I listed are what was given in my Kawasaki manual.
There is a chart at the front of my manual that lists road speeds for each gear in kilometers, doing the conversion for top speed (.6214 miles per kilometer roughly) a listed speed of 220 kph is roughly 112- 115 mph. I'm halfway there at 4,500 rpms, am I on target or geared too tall?
I'm trying to set this bike up for putting into work and back.
  • cuddies
  • cuddies's Avatar
Re: Engine rpm related to actual mph?
15 May 2007 19:13
#140450
Tall gearing means your gears are long. Sounds to me that your back sprocket was raised (teeth), or your front sprokect was lowered, or both; this would lead to lower gearing, which is accelaration.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
15 May 2007 19:30
#140453
you are on target with the chart
speedo may be reading a tad high which is common...
  • OKC_Kent
  • OKC_Kent's Avatar
15 May 2007 20:47
#140496
It sounds normal, similiar to mine. here is a link to a neat chart. Plug in your info into the pink area. Play around with sprocket sizes, tire sizes, and see what you get. With stock B1 info you will see a top speed of 115-117 mph.
www.wotid.com/tls/files/gearing_v12.xls
Post edited by: OKC_Kent, at: 2007/05/15 23:48
Cashion, OK
78 KZ650 B2 85,000+ miles
  • BSKZ650
  • BSKZ650's Avatar
16 May 2007 04:47
#140541
that sounds about right to me, havent rode the 650 in a while though. tire size will change the rpm some dont know about bikes, but on the race car 1 inch is equal to about 100 rpm change up or down
77 ltd1000, current rider
76 kz900, just waiting
  • pyxen
  • pyxen's Avatar
16 May 2007 05:48
#140548
I've asked before, but never got an actual answer.. Is it possible to change the gearing on a shaftie, to lower it a little, so that my 60mph is below 5grand rpm? It sits around 5250 right now.
84 KZ550-F2 LTD
93 ZR550-B4
  • barquirt
16 May 2007 08:56
#140593
I don't think it is very easy to change the final drive ratio on a shaft-driven bike. You'd have to go in and figure out a way to modify or replace one of the gears in the shaft drive setup somehow I believe...
