kz650 oil pan gasket? stubborn leak
- scumbag
- Lewd, Screwed, and Tattooed
14 May 2007 12:26
so I have been fighting with my oil pan to get it to stop leaking to no avail...
done it all...liquid gasket...had made gasket..bla bla bla...even tried a new pan all together
so I was thinkin maybe one of you have an oil pan gasket sitting around possibly? OOOooorrr maybe some other brands of liquid gasket I could try that have worked for you?
thanks all
thanks all
sept.1976 kz650
1980 kz650
1980 kz650
- Draco
Re: kz650 oil pan gasket? stubborn leak
14 May 2007 12:34
Try a nice smooth bead of Black RTV. The trick is to let it cure BEFORE you install the pan. Haven't tried it on my bike yet (no need yet). But it's worked well on various other projects, Including intake manifolds, and oil pans.
Good luck!
Good luck!
- BSKZ650
14 May 2007 12:51
if you have done that much work and it still dosent seal, are you sure it from the pan and not someplace else running down? just a thought, seems like you should have got it with what you are doing
77 ltd1000, current rider
76 kz900, just waiting
- RonKZ650
14 May 2007 13:21
The "oil pan gasket leaking" is the exact same idea as "head gasket leaking". Same fix, not a gasket at all, but hardened o-rings. They use 3 92055-077 "O" RING O.D.=19.5 These will leak. A gasket on an oil pan will never go bad unless it was installed wrong, and no sealer is advised or necessary.
- scumbag
14 May 2007 14:58
Well do any of you goons have a gasket? I really just do not want to buy a whole gasket kit...have not seen them for sale singularly anywhere
the pan that I have right now has no marred surfaces and I just got in the mail today new rubber "O" rings...I really just want to cave and get a gasket...sick of doing the whole liquid route
sept.1976 kz650
1980 kz650
1980 kz650
- The Milkman
14 May 2007 17:52
Sorry, but this, "goon" as you call us doesn't have a gasket. If you have been though all that and it still leaks, seems there is an uneven mating surface somewhere on the block or pan.
- The Milkman
14 May 2007 17:53
double post,:blush: :blush:
Post edited by: The Milkman, at: 2007/05/15 00:55
- RetroRiceRocketRider
14 May 2007 18:16
Brian,
I know they don't have them listed, but check with Jeff at Z1 Ent and see if he can get you the gasket.
You could also check with this eBay seller to see if he/she has the gasket available seperately:
MOTORCYCLE PARTS BARN
I've bought from them before and they WILL go the extra mile to help out, even if it's only a part worth a few dollars.
You do know that the '82 KZ750-R1/'83~'84 ZX750-A1/A2 GPz's (not the Turbo though), ZR750 Zephyr, ZN700/ZN750 as well as a most/all of the KZ750-4's use the same oil pan gasket, right?
That's how I've found all of the ones I've bought in the past on eBay. Heck, I don't think I spent more than $15 including shipping for any one of them, and I've bought at least 6.
I don't know if it would make a diff or not, but are you installing the 3 smaller o-rings Ron mentioned correctly?
The flat side should go into the "groove" in the engine and the "V" shaped side faces the oil pan.
I usually give them a light coating of grease to prevent them from falling out of the little grooves in the engine before I can get the pan placed up against them and hold them securely - haven't had a leak yet.
If you're not able to locate an oil pan gasket, I just MIGHT be persuaded to part with the extra one I have.
Post edited by: RetroRiceRocketRider, at: 2007/05/14 21:19
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- RonKZ650
14 May 2007 18:29
Any dealer should have the gasket or can order you one for $15 or so. 11009-1983
- Bluemeanie
14 May 2007 20:33
I've only done my pan gasket once (removed for stripped pan bolt) cleaned surface,installed gasket dry and never leaked. So I agree that you have a irregular mating surface problem or "O" ring problem.
