f@&*%ing bike runs irratic and idles 4-5k rpm when warmed up
- ratridekz750
16 May 2007 19:26 #140788
by ratridekz750
Replied by ratridekz750 on topic f@&*%ing bike runs irratic and idles 4-5k rpm when warmed up
ha ok well thanks for all of the help everybody, turns out when its doing that high idle crap i couldn't notice a change in idle with the spray trick, however i repeated that and noticed it would smoke out the tail pipe, the rod that runs through both carbs for the throttle linkage was leakin like a sive, so for a whopping 30 cents a piece i just bought some rubber caps and put them right over top, they allow for the throttle to still move freely and BAM purrrrrrrrs like a kitten, yea its a temporary fix limited by the weathering life of the rubber caps but hey for 30 cents a piece i think i can afford to replace them as often as necessary.
ratride for life!!!
ratride for life!!!
- Whheezzzz
12 Aug 2008 23:03 #231718
by Whheezzzz
1977 KZ750B Twin
Replied by Whheezzzz on topic f@&*%ing bike runs irratic and idles 4-5k rpm when warmed up
if you dont mind me askin what kind of rubber caps did you get to cover up the throttle linkage ?? And also i wonder what would be the permanant fix to it? Thanks
1977 KZ750B Twin
