Oil Filter KZ900 - Wix
  • austin3119
  • austin3119's Avatar Topic Author
13 May 2007 17:42
#139757
I'm putting in an order for some oil filters for the Yukon and the Altima. I like the Wix filters. Do they make a filter for the 1976 KZ900 . The EMGO filter that I usually use has a number of 10-24400 .
Thanks in advance.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Oil Filter KZ900 - Wix
13 May 2007 17:53
#139759
Here's the numbers,Austin...
Big A # 96942
Champ #P7012
Fram #CH6013
Purolator #ML16813
Wix #24942
1977 KZ1000 A-1
  • austin3119
14 May 2007 10:37
#139910
Sandy,
Thanks a lot. I appreciate the help.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
14 May 2007 17:39
#140009
You're welcome...any time,Bud!B)
1977 KZ1000 A-1
  • JMKZHI
  • JMKZHI's Avatar
Re: .
15 May 2007 07:18 - 03 Dec 2008 10:59
#140224
del
Last edit: 03 Dec 2008 10:59 by JMKZHI.
  • austin3119
15 May 2007 08:37
#140255
Actually you're right about that. Wix makes the Napa Gold, Silver and the cheaper Napa Pro Select series. They also provide filters for Carquest.
I was skeptical about the Pro Select Series from Napa. Their only like $3.79 or something like that. So I grabbed one and compared it to a genuine Wix. The Pro Line filter has Affina stamped on the box (Wix's parent company). It also has Gastonia, NC stamped on the box which is the location of one of Wix's plants. The filter casing on the Napa Pro Select series is the same as a regular Wix filter (same shape, size, color, 8 holes on the top etc.... But if you look down inside the filter the filters are different, and the genuine WIX is heavier.
Wix probably doesn't make any junk, but interesting none the less.
