kz 750 l4 1984 Ignition timing help
- ZiGoUnE
13 May 2007 12:55
How can i do that,i got 2 kz 750 on for piece the other for driving but the timing is rong on my bike backfire....
how timing that pls twin cam and crank shaft spesification pls
Post edited by: ZiGoUnE, at: 2007/05/13 16:18
- steell
Re: kz 750 l4 1984 Ignition timing help
13 May 2007 13:49
You can't adjust the timing without modifications.
Chances are the wiring to the coils is reversed. One coil fires #2 and #3, the other fires #1 and #4. It is possible you have the wires going to the wrong coils.
- ZiGoUnE
13 May 2007 15:04
i try to adjust the twincam and the crank sahft now amy bike make backfire i need just the seting sprok and crink shaft
thx
thx
- steell
13 May 2007 20:04
Click on this
LINK
and download the Factory Service Manual, and click on this
LINK
for really good tips on setting the cam timing. The second link covers the GPz750, but it's the same as the KZ750.
Hope that helps
Post edited by: steell, at: 2007/05/13 23:05
Hope that helps
