Yoshi pipe help?
  • harm
  • harm's Avatar Topic Author
  • Tom
Yoshi pipe help?
12 May 2007 12:56
#139436
How do i get the can off? I removed the three bolts and figure it would slide right off. I even tapped on it with a rubber hammer. I need to get it off so i can fit the rest of the pipe in a sandblaster.
Thanks for any ideas!
Post edited by: harm, at: 2007/05/12 15:58
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • harm
  • Tom
Re: Yoshi pipe help?
12 May 2007 12:59
#139437
a little closer pic
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • Pterosaur
  • Pterosaur's Avatar
12 May 2007 13:06
#139442
1. Clamp the pipe in a vise carefully between a set of wood blocks.
2. Heat the junction with a propane torch - moderately - don't go ape for a cherry glow.
3. Spray the junction with "Blaster" or WD-40 and steer clear of the smoke.
4. Tap harder. - using a wood block or a rubber sanding block as a cushion on the can lip, alternating side-to-side. ;)
Might still give you a bit of a problem, things look to have been warped a pit out of round when the bolts got cranked down.
  • Pterosaur
12 May 2007 13:29
#139447
Just had another idea...
To avoid marking up the can, get yourself a muffler clamp large enough to fit over the pipe but not over the lip of the can, wrap the parts of the clamp that will make contact with the can with duct tape, install it as a collar over the pipe, grab the plate end with a pair of vise grips and whap on the clamp around its circumference.
Much easier to get uniform whaps on the can without marking it up. ;)
Post edited by: Pterosaur, at: 2007/05/12 16:30
  • harm
  • Tom
12 May 2007 13:45
#139450
I got it off!! Thanks Pterosaur! Worked like a champ:) I am still not sure if it will fit in my sandblaster at work. I will have to wait till monday to see.
Thanks again
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • Pterosaur
12 May 2007 13:54
#139452
You're - glad it worked out okay.
