Repacking clutch straight forward?
- Lorcan
- Speed Loony
Re: Repacking clutch straight forward?
14 May 2007 04:39
Takes me about 20 mins to change my turbo clutch, but I have done it a few times :whistle: . I don't drain the oil, just lean the bike against a wall (have it in gear so it can't slide). If I remember rightly the last friction plate to go in gets rotated one tang on the 650. Genuine plates are best.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- pyxen
14 May 2007 05:19
Shizzle.. I'll be opening up my clutch tonight then!
I've wanted to check that stuff out for a while. Erm, actually I should probably get a gasket first, eh? Or I guess I could make one..? Can you get gasket material at most autoparts stores? Or could I just use the gasket goop in a tube?
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
